best clutch?
Don't go with Exedy. After 38,000 miles on the stock clutch I switch to the pricey Exedy clutch ... 1,200 miles later the Exedy failed. Excedy was properly broken in.
- MSM
- MSM
Act clutch
Latest rev Honda disk
Comptech lightweight flywheel.
Stiffer, quicker engagement, little slipping when you don't want it, nicer throttle response for rev matching....
i agree, ACT PP and newest ver. of stock disk and a light flywheel is a good combo.
i just installed a prototype ACT clutch in my car and have tested on street and track. it makes the "noise", initially bad, but now mild after break-in but my car is essentially only a track car, so i'm not bummed. but it otherwise is great and it seems to be well suited for my S/C car with 2.0 way clutch type diff and race tires, it's slippable and perfectly streetable but is grippier and time between shifts reduced. the diff is really not streetable. i have given ACT feedback including the noise issue and told them that is unacceptable for street driven customers. it is built from a exedy sourced plate with viper friction material, non puck, oem style with springs but with thinner marcel(cushion backing).
i don't know if they plan on marketing it. however, i have comptech flywheel . if anyone with a stock flywheel wants to be a guinea pig, they would like to test it in another car as it may not make noise when interacting with heavier flywheel.
Really? Wow I'm gettin a lot of ACT recommendation that I'd expected. I was actually looking at the Clutchmaster stage IV clutch kit. 170% more grip or somethin like that. Anyone have the clutch and would like to suggest something about it?
Tuner
Tuner
I was under the impression that our S's rear ends would not be able to handle such a grippy clutch. I thought it needed a bit of slipping so that it wouldn't blow.
By the way , now that I have updated the clutch, what will be most likley to break, the final drive gear or the differential?
I am about to have the 4.44's installed.
