BEST CAI with NO CUTTING?
Originally Posted by xviper,Oct 7 2004, 12:23 PM
If you did the intake AND the VAFC after the first dyno, how do you know how much increase was attributed to what? VAFC alone has been reported to give up to 10 HP all by itself. When you do more than one thing at a time and then get numbers, you can't say that the gain was applicable to one or the other. Or did you dyno stock, then intake, then VAFC. What were the numbers for each?
Originally Posted by specialque,Oct 9 2004, 07:10 AM
The car was dyno'd twice, bone stock...210whp, then again with comptech CAI and v-afc with the engagement point moved...no a/f tuning was done = 225whp.
"I'd say it makes power."
Since you got the 15 HP with BOTH, you cannot attribute this gain to the intake alone. As I indicated earlier, it has been posted here that a vafc can net you up to 10 or more HP. If this holds true in your case, then the intake is only responsible for about 5 (although this analogy is still quite vague).
(Please don't take this as a flame. It is not meant to be.)
he says no A/F tuning was done with the vafc, only the vtec engagement point was altered. if that's true, then the gains were mainly from the intake.
although i find a 10rwhp gain a little far fetched for an intake.
so the 04 comptech requires no cutting? i heard that it can vibrate against the hood. not sure if this is still an issue
what the opinion on these
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=38634
Gibbo (Locutos)
02-11-2004 06:19 PM
