berks testpipe simulator still throwin cel.
Old 02-19-2007, 04:05 PM
Slows2k's Avatar
Find an autozone and get it pulled for free
Old 02-19-2007, 04:16 PM
notyourfriend's Avatar
that would be the correct thing to do... unfortunately, i went to reset the ecu between posts. it will/should pop up again and i'll take care of it at autozone. if it's my secondary o2, hopefully that second anti fowler solves the problem... but NOW the question is, will 2 anti-fowler mods affect anything? will it be safe for my car? think i should back to the cat LoL
Old 02-19-2007, 04:26 PM
S2kMarkus's Avatar
I added the defouler to my berk just to be safe. 8k miles later still no problems.
Old 02-19-2007, 05:02 PM
so you're not getting any cel at all?
somebody above stated the ap2 o2 sensor is more "sensitive" than that of the ap1. what i'm afraid of is it adversely affecting the car. i have yet to confirm what the secondary o2 does...
Old 02-19-2007, 06:00 PM
Slows2k's Avatar
Old 02-19-2007, 06:24 PM
44Runner's Avatar
OK
The second O2 sensor is simply to check up on your emissions system. No damage is done by the CEL, but you do not want to drive around with it on because it might cause you to miss other non-related codes that could be thrown. The berk TP even though it is billed as the only one to come with a built in CEL fix still throws a code on a lot of peoples cars. Their "fix" is far from 100% as you can see in this thread. To date I have never heard of the anti fouler trick not working when done properly on any testpipe...
deathsled's Avatar
oh yeah its completely harmless for my car, but yours is sure to blow up.....
the secondary o2 sensor is just there to see if there is a cat installed and its functioning properly. All the "mechanical o2 simulator" mods do is pull the o2 sensor out of the exhaust stream enough so that it gets a lower reading and thinks the cat is doing its job. If the built in one on the berk isnt enough, then adding the sparkplug anti fouler just takes the sensor out of the exhaust stream a little further to keep the CEL off.
Old 02-19-2007, 06:40 PM
[QUOTE=Slows2k,Feb 19 2007, 07:00 PM]
Old 02-19-2007, 06:54 PM
Originally Posted by 44Runner,Feb 19 2007, 07:24 PM
OK
i'm not to worried about anything right now... unless Honda sold me a lemon. the car had 10 miles on it when i bought the thing.
i searched for people having the same problem and i found a couple of threads but no solutions stated. I'm going to go buy that "cel fix" tomorrow after work. hopefully, that solves my cel otherwise, i'm going to blow up this s2k.
Robertttstyle
05-28-2014 04:50 PM
HighwayStar
04-01-2008 04:06 AM
jack.tsu
09-09-2007 03:57 PM
nightcrawler7188
05-28-2007 05:15 PM
IwantaS2000
08-23-2005 10:51 AM
Quick Reply: berks testpipe simulator still throwin cel.
