berk test pipe 63
berk test pipe 63
yo guys..just installed the test pipe today..sounds awesome!!
the only problem is that i hear a buzzing noise in between 3000-3500k
its the buzzing noise that i hear from most civics and integras with stock exhausts...like a high pitched bee...ive done some research and havent really found the answer as to why..maybe you guys might be able to help??
it buzzes when i accelerate and deccerlerate in that rpm range
installed a 63mm test pipe with my stock piping..
kind of sounds like the buzzing in this video..but not as bad
[media]http://www.youtube.com/watch?v=JsQKE52ialY [/media]
i posted this in the modifications section..but i dont think that was the right place.
I had the same issue when I installed a test pipe.
It sounded great in certain rpm's, but I hated the added buzzing/raspiness the test pipe gave my exhaust. I felt like it cheapened the car, it honestly sounded like a 93 civic dx running a straight pipe.
I found the sound was the worst during high rpm shifts as soon as I'd let off the throttle.
JMO, it sounds like a cheap exhaust. If you pull the converter from the stock exhaust or a low quality aftermarket it usually sounds like this. Get yourself a quality hot gas piece and this will disapeer. Or just put the converter back on. good luck.
MegaTRon
10-12-2011 12:52 AM
