berk HFC issue.
i apologize if i came off in a selfish way. my intend were to not put myself in a position where i could jeopardize Berk Technology by affirming conclusions stated by your locals. i just wanted to share my issues with all of you. by all means please share issues as much as you/everyone else like =)
I've had my berk 70mm hi flow cat on for about a thousand miles so far and it has no problems at all just made my exhuast sound better. i hope it doesnt wear out to quick, mine has more like heat looking marks like the dark blue ishness. how long did you have yours on b4 it started this weird sound ?
I've had my Berk HFC for 3-4 years now without problems til I began to get a P0420 cel. I really never noted a change in sound so I'm still using it. The fix was the same as for the test pipe (two anti-foulers).
Go to Autozone and buy a pkg of two antifoulers. Use both because I tried using only one and that didn't work. Cheap fix, but you will have to drill one out so the O2 sensor will fit. Piggyback the drilled one on top of the undrilled one. The anti-foulers come in the small red (HELP!) packages. It wouldn't hurt to take the O2 sensor with you to insure you get the right size. GL
