Bent Valve. head damage?
I have a problem with a bent exhaust valve, or valves.... I have narrowed the problem down to the #3 cylinder, compression is leaking out the exhaust valves causing a Rich misfire at Idle...
what kind of repair work am I looking at? at most 2 valves replaced, I know that, but what kind of head damage can a bent valve cause? head machining work?
I am assuming that I am pretty lucky as I caught this problem before the valve dropped, and that my car is still running surprisingly strong...... must mean the valve is bent just a tad.......?
thanks
thanks
Originally Posted by Sideways,Jul 23 2007, 07:20 PM
Bent or burnt. It will have to come off to see if there is piston damage.
Originally Posted by negcamber,Jul 23 2007, 07:20 PM
Heresnowhy's head was not damaged by his 2 bent valves. He was able to get back on the road with new guides, valves and retainers.
You would want to go ahead with new guides anyway. I doubt the machine shop would allow it to come back to you without them anyway. It's just common sense to replace what normally wears as long as you have the head apart.
I would bet any piston damage will be minor. After seeing Heresnowhy's head off the car when 2 valves bent (one snapped a stem), there was very very minor damage to the piston top. The carbon build up was worse than the piston damage.
i had bent exhaust valves in cylinder #3 as well.
i had all my exhaust valve guides replaced as they were all warped, dunno how or why.
i suspect the valve damage was due to a mis-shift from 3rd to 2nd, although i didn't notice symptoms until 2 years later (compression and leakdown performed immediately after the mis-shift checked out fine).
how did you bend your valves, was it a missed downshift?
anyway, to answer your question, i didn't even have to replace the valves, just relapped the face. replaced all the exhaust valve guides, and that was it, and my leakdown showed 66% leakage in cylinder #3
so hopefully my head can be salvaged and all I would need is 2 new valves, all new valve guide and I would be good to go...... portflow is telling me 250 for labor on the valve job, and surface...?
how much do you think the valves and guides would run me?
i forgot the price breakdown...but alaniz was cheaper than portflow...
not to mention portflow refused to fix my head because they said it was driver error...and it would be a headache for them to deal with me cuz i would blame them for future problems...and they quoted me a ridiculous price even though they wouldn't work on my car.
so i took it to alaniz.
i don't like portflow.
