Bent valve?
Old 02-21-2016, 11:30 AM
Billman250's Avatar
Received 1,382 Likes on 829 Posts
Originally Posted by jkelley
I don't think I've heard of even ONE example of someone that ACTUALLY needed to replace even a SINGLE valve spring on these motors... so that's red flag #1 for me.
Number of valve springs that I have had to replace in 13 years of working on an S2000, ESPECIALLY on a car with zero symptoms, is zero.
Compression and leakdown tests are diagnostic jobs. Be wary of any shop offering it as "complimentary", especially one trying to sell you WELL OVER 2k worth of unnecessary work under false pretense on a perfect running car.
Old 02-22-2016, 02:52 PM
steven88's Avatar
The fact that their numbers are higher across the board isn't worrisome, gauge calibration probably. The fact that cyl #3 tested lower initially and now #2 is the suspect cylinder is the red flag here for me.
The fact that that they did a "complimentary" compression/leakdown is the 3rd red flag. It takes a decent amount of effort and isn't a hard-and-fast result, and has to do a lot with listening to air noise. Almost sounds like they were wanting to set you up.
$2k for a full valve job isn't unheard of, but there are cheaper/better alternatives. I paid a little more than HALF that for the best quality work you can find. PM Jordan (forgot his username) or Billman250.
+1
These kind of threads sound awfully familiar. I'm wondering if it's who I think it is.
Old 02-22-2016, 03:47 PM
Car Analogy's Avatar
Received 1,421 Likes on 1,063 Posts
Yes, it is...
Sent from my SM-G920P using IB AutoGroup
Old 02-22-2016, 04:23 PM
Billman250's Avatar
Originally Posted by Cevin
I took my car into a local shop to get the AP2 retainers put in
Were your retainers deemed fractured, or were you just upgrading?
Old 02-23-2016, 04:54 AM
jkelley's Avatar
Yes, it's threads like these that really tighten my sphincter whenever I think I may have a car problem. It kills me to think that I can bring my car in, pay thousands of dollars, and they do more damage than good or "fix" something that wasn't broken. And it's a widespread problem. I'm hoping (praying) that my perception is jaded because I learn about the instances on these boards and hope that there is a large chunk of people that take their cars to get worked on everything is fixed no problem, and they're on their merry way with no issues. But somehow I believe that's just not the case.
Old 02-23-2016, 11:18 AM
Cevin's Avatar
i just purchased the car, and wanted to upgrade for peace of mind.
Old 02-23-2016, 11:21 AM
Cevin's Avatar
took it to a different shop and it is indeed leaking (now in cylinder 4 (95%!)
this is so strange that all of the tests are so different... the shop i took it to i trust a lot, but they are a German shop, you think that matters for such a simple test? or maybe i did lots of damage at autocross this weekend?... i didn't really even red line it, so not sure whats going on.
Old 02-23-2016, 11:36 AM
08S2000's Avatar
If you like working on cars, I would recommend you to get a compression test kit to verify 3 previous results. If your numbers are consistant, test again to confirm. You can only trust yourself...
Old 02-23-2016, 11:57 AM
s2000Junky's Avatar
Your car would have a severe misfire in a cylinder with 95% leak down, the cylinder wouldn't even likely fire, it would just sound like running on 3 cylinders and be throwing codes left and right. There is no way. Man what is wrong with these shops? Isn't this basic mechanic school 101?
Old 02-23-2016, 12:02 PM
Boundsyo2's Avatar
Where do you live? Maybe someone on here can help??
Quick Reply: Bent valve?
