bent headlight support?
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Hey guys, unfortunately I had an accident recently, and I bent my right headlight support. As a result, even a new fender and bumper won't line up with the headlight correctly, even the mounting threads for the fender are bent. Basically when I match the fender and the front bumper the headlight is pushed in a little. Which parts do I need to replace?
My question is, can I just replace the headlight SUPPORT, and not the whole headlight assembly? The headlight works perfectly fine. If yes, how much would it cost and where can I order it?
Thanks, frank.
Thanks, frank.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
what color is your car and where are you located, i have mine that i am not using due to intercooler pipes
yes you can just order the headlight supports on their own
car's berlina and im in norcal, cupertino area to be exact.
Why does color matter though?
Just to be clear, I need the brackets that the fender also mounts to. I hope I'm calling it the right thing.
