Belt whine under load
I am looking for some advice after watching numerous videos and reading a few threads regarding "belt whine".
Symptoms:
Video of pulley tensioner inspections
There is some clear wobble on both the idler pulley and the tensioner pulley. Would this cause the whine I am hearing? Any suggestions to test and/or eliminate some causes?
Thanks in advance,
Matt
Symptoms:
- Belt whine when under load (moving in gear)
- Whine gets progressively louder and higher pitched as RPMs raise
- Whine does not occur at idle
- Whine does not occur at idle while in gear w/ clutch in
- Whine does not occur unless the car is under a load, in gear, and moving
Thanks in advance,
Matt
May be time to purchase a new idler and/or tensioner pulley. I'm assuming you've exonerated the belt itself? Where is the tensioner arrow pointing on the tensioner housing? (i.e. is it time for belt replacement?)
Indeed. The belt "shouldn't" be the direct culprit although I recently replaced it which may have put the last needed strain on the pulleys you're referring too and, ultimately, caused the whine. I am trying to get some clarification on what noises occur when each of the pulleys begin to degrade because of all the posts I've read only 1 or 2 mentioned "a whine sound".
I bought new bearings and will replace them this weekend. For a cost of 21 bucks I figured I would just start there. Based on what I've gathered from this post, it should be fairly straightforward.
Thanks,
Matt
Have you done anything to your timing chain tensioner?
Aliminator
08-17-2012 04:15 PM
rocketman
05-18-2002 07:41 PM
