Battery tray
Battery tray
Last time I was poking around the engine bay, I noticed the battery tray was looking krusty.
I should have taken a pic before but this was after I removed all the loose paint and rust.
I had this so I used it for an intermittent fix
Under the tray wasn’t as bad but I cleaned and prepped it too
Couple quick coats and that should keep it from getting any worse
Hit the bolts too
I think this spot is so prone to rust because of the plastic tray that traps moisture.
If I ever pull the engine, I’ll respray the entire bay in Spa Yellow.
Hit the bolts too
The following 2 users liked this post by Dibsen:
GBR! (03-31-2024),
windhund116 (03-31-2024)
