Banjo Bolts - Necessary Upgrade?
#21
Originally posted by beroznikmal
xviper,
what happened to the guys that stripped their threads? The hole is pretty hard to get to and I would imagine that the only way to rethread them is to take the block apart...
Beroz
xviper,
Beroz
In the case where the bolt was cross threaded (DIY), the owner used some sort of metal adhesive to re-install the bolt. As far as I'm aware, so far, this has been working OK. The threads are a very fine pitch - difficult to clean and difficult to re-tap. I'm not sure a helicoil would work here.
#22
When I did mine, I noticed that it was particularly difficult to thread the bolt in the first cylinder. The threads on the engine are very delicate and require extra attention.....
Beroz
Beroz
#23
Access to the #1 jet bolt is impeded by the presence of the oil pump hardware. Also, the threads are not positioned straight "up and down" as the engine block itself is at an angle. One needs a flex extension of some sort so that the "slightly off angle" can be achieved.
#25
Certainly if this install is bungled, Bad Things can happen, so some caveats are justified... But as Prolene mentions in my install thread, this job is really Mechanics 101. (OK, maybe the final exam in Mechanics 101. ) If you take your time, use the proper tools, maybe invite a buddy over, I think you should have every expectation of things going smoothly.
#28
I just had my bolts upgraded last week during the vortech install. The one in cylinder three was loose. Would have hated to see that work it's way out. I was just wondering if anyone else had the same experience.
