bang noise from the rear
Old 01-26-2012, 01:59 PM
I<3myap1's Avatar
Default bang noise from the rear
lately I've been getting this bang noise coming from the rear of the car under hard braking or going up drive ways. It sounds as if I have a bowling ball pounding against the car under braking. I was thinking it could be differential mounts or the sway bar? Anybody else have this problem or know what it could be?
thanks for your time
-Tyler
Old 01-26-2012, 02:43 PM
ahrmike's Avatar
are you slammed? What sort of coilovers are you on? It almost sounds like the springs arent preloaded/no helper springs so the coils are popping and lifting/reseating/shifting. Its also possible you have stuff loose in the spare tire/tool tray area.
Old 01-26-2012, 03:01 PM
I<3myap1's Avatar
In the rear I don't even have a finger and in the front I have a tight one finger gap. Currently on Buddy Club N+'s. The trunk is pretty much clean.
Old 01-26-2012, 03:08 PM
ahrmike's Avatar
Get a sharpie or whiteout pen and mark your spring and spring perch. If the marks move away from each other then you know for sure...
by tool tray I mean the partition under the trunk - where the jack and lug wrench exists. Have you checked there? The spare tire area is that bump on the right side of the car. Are the BCs on pillow ball mounts or OEM mounts?
Old 01-26-2012, 03:14 PM
I<3myap1's Avatar
will do that! yup the partition under the trunk is normal, everything is in its place. The BC's are on pillow ball mounts. Thanks for the help btw!
Old 01-26-2012, 03:19 PM
importrule's Avatar
is this like a random clunk that happens sometimes when you go over bumps but it doesn't always appear?
Old 01-26-2012, 03:24 PM
ahrmike's Avatar
Nps man. I haven't had any experiences with pillow ball mounts, but a friend of mine who was on tein pillow balls said those were the cause of his noise.
Old 01-26-2012, 03:34 PM
I<3myap1's Avatar
it always happens when I go in drive ways or brake hard
Old 01-26-2012, 03:37 PM
importrule's Avatar
hmm, i guess i have a different noise from you then...
good luck on finding out what it is.
Old 01-26-2012, 03:46 PM
I<3myap1's Avatar
thanks
Quick Reply: bang noise from the rear
