Ball Joint Tool
Ball Joint Tool
I prefer the one suggested by Ray but whatever you do DONT use a fork like this one:
Tie Rod Separator
It kills the ball joint.
Good luck!
Tie Rod Separator
Good luck!
Originally Posted by eCrS2k,Nov 9 2007, 10:19 AM
http://www.harborfreight.com/cpi/ctaf/Disp...temnumber=46821
this is what i use, only because i never have any luck with ball joint removers,
ball joint+me=
ball joint+me=
That should be incorporated into the swiss army knife
What you need is a BFPB(BIG F****N PRY BAR). When I had to remove my diff for gears this is what my brother inlaw brought to use who is an ex mechanic, it is basically about 3 feet long with a flat slightly curved end the other is pointed and it is about an inch in diameter or more. Both ball joints were done in less than a minute. If you saw how easy this was you would crack up.
and no gouged boots.
Swiftoy
Swiftoy
