Ball Joint puller?
Old 06-11-2003, 02:13 PM
Stratocaster's Avatar
Default Ball Joint puller?
Ok, where can I find a ball joint puller? I need to drop my rear diff. Anyone know where I can source one?
Jeff
Old 06-11-2003, 04:53 PM
jerrypeterson's Avatar
Sears is where I bought mine.
Old 06-11-2003, 05:00 PM
s2knikko's Avatar
any auto parts store... its called a pickle fork.... if that is indeed what you are talking about... shouldnt be more than 10 or 15 bucks
Old 06-11-2003, 05:21 PM
davepk's Avatar
you dont need to pop a ball joint to get the diff in or out. After you disconnect/loosen all three shafts you'll need to support the diff and remove the 2 forward brackets and remove the 4 nuts in the rear. At that point move the diff towards the front of the car by a couple of inchs and then to one side of the car. That will give you enough room to disengage one of the ouput shafts from the diff. Remove that shaft then move the diff to the other side to remove the second shaft. The diff will then drop out nice and easy.
Old 06-11-2003, 06:59 PM
Actually a pickel fork will damage the boots. Honda has a differant type of tool and that was more what I was looking for.
Davepk
You dropped your without popping the ball joints? I was thinking about that but wanted to have the tools in hand so if I needed to i could. Shopping for a tool in the middle of the job is a pain.
Old 06-11-2003, 07:29 PM
xviper's Avatar
It is possible to do what davepk said. I found it very hard to do alone. Two people would have made this easier.
What you need is one of these:
Old 06-11-2003, 07:51 PM
xviper's Avatar
OK, by request, here's a couple of better photos:
ps. A pickle fork will work BUT, most likely your grease boots will be toast.
Old 06-11-2003, 10:20 PM
RT
RT's Avatar
I pulled this from this old post:
[QUOTE]Originally posted by RT
[B]
Rev, I've been using one of these to pop ball joints (done the rear lowers about 5 billion times now ) instead of the gear puller type deal.
Old 06-11-2003, 10:28 PM
RT
RT's Avatar
Jerry can vouch for the effectiveness of this tool when he couldn't get the toe link off the rear spindle for a whole week and I came over and did it using the MAD RABBIT tool in two seconds while he was looking for a flash light or some sh!t (well maybe he can't vouch since he didn't actually see it happen, for all he knows, I just kicked it loose )
Old 06-11-2003, 11:50 PM
s2knikko's Avatar
to the best of my knowledge that a universal puller not a ball joint tool... cause what you asked for was a ball joint tool (picklefork) so haha just playin bro... glad ya fingered out what ya needed
Quick Reply: Ball Joint puller?
