Balancing flywheel/PP assembly
I am currently replacing my clutch with OEM parts. Do I need to get the flywheel/pressure plate assembly balanced together before re-assembly? Or do the parts come pre-balanced from the factory? I can see the pressure plate only fits up one way.
I have all new components:
Flywheel w/ new pilot bearing
Pressure Plate
Clutch Disc
Throw out bearing
Pressure Plate
Clutch Disc
Throw out bearing
![](http://inlinethumb50.webshots.com/12209/2620459540102826257S600x600Q85.jpg)
![](http://inlinethumb59.webshots.com/20474/2866248640102826257S600x600Q85.jpg)
Both are balanced independently.
The PP with rivets and the FW with drilled holes.
And IMO the need to be at 9000 / 8000 rpm.
These are an ACT PP - basicaly an OEM PP with a stronger spring and a Comptech FW.
![hello.gif](https://www.s2ki.com/forums/images/smilies/hello.gif)
joefish1298
11-12-2013 01:23 PM
riceball777
10-19-2013 05:50 PM
jyeung528
01-27-2008 07:41 AM
