Bad valve seats?
Old 06-18-2014, 03:36 PM
WestSideBilly's Avatar
Originally Posted by jordanksartell
In our engines, generally burnt valves and seats are caused by the valve clearance being out of spec. The valve isn't fully closing 100% during combustion thus burning and pitting the valve and seat. Other things can cause burnt valves as well such as improper timing and poor air/fuel ratio.
The valves have been properly adjusted since I've had the car. No clue about before then.
Since the ECU controls timing and A/F, could this be a case of something else causing the ECU to over compensate (maybe a bad injector)?
Old 06-19-2014, 04:21 AM
MM3Kwolik's Avatar
It's possible, but I'd lean towards the idea that a previous owner had the valves out of spec for a bit. All it takes is running the motor for a little while with a valve out of spec causing excess carbon buildup. That buildup in turn will cause the valve to not seal properly, allowing combustion gasses to get past the valve and seat in turn burning both. It's never a bad idea to have your injectors serviced when performing major surgery like this anyway. Only costs about 20$ per injector from a number of the big name companies online and you'll end up with like new injectors in the end. Definitely worth it in my opinion.
Old 06-19-2014, 02:03 PM
Yeah, I planned on getting the injectors tested/cleaned. I have 4 from my old motor which I might do as well just to have some good spares.
Dicky s2k
05-16-2016 10:40 AM
clio
12-05-2014 05:30 PM
surfer_crx
07-24-2014 11:14 AM
s2000powered
07-09-2013 11:51 PM
booski
10-10-2009 02:09 AM
Quick Reply: Bad valve seats?
