Bad TPS or feedback from the lightweight flywheel?
Hey guys, So recently I had replaced my clutch/flywheel due to the other one going out at the track. I've put about 400 miles on it and it's felt great so far. My wife has a G35 with the same combo so I already knew what I wanted when it needed to be replaced. My concern is that I cannot distinguish whether the clutch is what I'm feeling or my TPS is going. Randomly when driving, Mostly in 1st and 2nd gear I feel a jumpy sensation. This happens sometimes while I'm already in gear coasting with my foot off the clutch and my other firmly on the gas and even sometimes when I'm at 3-4k without touching either pedal really. I have also felt a minor spudder when I gas it up to about 7 or 8k under full throttle.
I know my map sensor has been going so I just ordered an OEM map to replace the one I have but based on the feedback I get from the car just in case that is actually it. Can you guys tell me based on your experiences what I might be dealing with? I don't intend on replacing the throttle body so if it comes down to it I'll probably just get an Omnipower replacement TPS if needed but I don't wanna waste the money if it could just be the flywheel. I don't feel this in our other car so I'm unsure if it's just an s thing.
I can't really comment on which or what it may be but I used a Bluetooth OBD2 scanner that linked to my phone which ruled out a TPS issue for me. I could see the live TPS position as I drove. You would be able to see if it does indeed jump or fall during the times you are talking about.
I think it was like $25 shipped. I use it all the time. Tons of useful data from our ECUs.
![thumbsup.gif](https://www.s2ki.com/forums/images/smilies/thumbsup.gif)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
I'm actually not sure. For my alternator for instance the sampling speed is much higher like once every second, but for coolant temp it only gives me lumps of temperature - unlike a true analog signal. For instance the temperatures I see are 178.6, 179.2, 180.6, 181.4 or something like that but if the temp is in that range it's going to pick one of those values. And I think it samples every 4-5 seconds.
When I tested my TPS the sample had to be at least ~0.1 seconds because as I was opening/closing the throttle the signal followed up and down very very quickly.
Originally Posted by shind3' timestamp='1412361735' post='23355497
[quote name='jkelley' timestamp='1412265739' post='23353772']
[/quote]
Cool, good to know.
What phone app did you use? Torque?
stinky_finger
12-20-2012 07:39 AM
IntenseImports
11-06-2007 12:45 PM
