Bad starter?
Bad starter?
Drove in to work this AM with nary a hiccup. Went to start the car when I needed to leave and got nothing. Catastrophic failure of the battery is what I thought, but that seems to not be the issue.
The motor turns slowly and even acted as if it fired once or twice, but just barely. I have attempted to start the car with a 1100 CCA Semi Truck battery (started with a smaller jump from a running vehicle). Jump went from positive terminal direct to the engine block to bypass any bad ground issues with no change.
The large jumper cables are getting hot so I know that it's pulling a lot of power.
I'm getting a tow home, and can do some more diagnostic digging once i'm out of dress slack and have more than a single small wrench and screwdriver to work with. I might have to go get more socket extensions to get at that top starter bolt.
Indicative of a dying starter? I've had them go bad on other vehicles, but never in a partially failed state and I'm worried that I'll get it off and it won't be the problem.
-- Chuck
liquid_helix136
02-15-2018 02:40 PM
S2Kevinn
03-06-2012 06:01 PM
