Bad Idle/Misfire Symptoms
Originally Posted by fireball,Sep 30 2008, 09:12 AM
what about changing the fuel filter ? and maybe a dodgy fuel pump on its way out maybe ? all well maybe an excuse to put a walbro gss 342 in
Originally Posted by 03AP1,Sep 30 2008, 12:28 PM
one of my friends is hookin me up with a fuel pressure gauge tonight.
mrblu... 60k on car... 7k on head and less than 2k on block.
It could be your IAC (idle Air Control) on the intake manifold that causing the idling problem. Remove it and clean it with some rubbing alcohol and try it, if its bad then replace it.
Originally Posted by jesusphish,Oct 1 2008, 06:05 AM
The S2000 doesn't have an inline fuel filter. It's more of a sock filter in the gas tank.
just did this last wk
the fuel filter is an entire unit itself connected to the fuel pump
and thats in addition to the fuel pump sock
Originally Posted by 03AP1,Sep 30 2008, 05:01 AM
--snip-- and dumped some octane booster and fuel injection cleaner and filled her up w/93 oct. Upon leaving the gas station, she started to bog like crazy. Drove her a bit further and the bogging was so bad that I had to pull off of the road. --snip--
Could the fuel injector cleaner and octane booster make her bog and idle rough like that???????? --snip--
Have you checked your injectors since you said your scanner said you had misfire. Mine did that when i replaced the motor in my car. Away to find out is turn the car on and remove your heat shield from the header. one of the header pipes was significantly colder than the rest and I had spark. I also broke my TDC CAM sensor when i replaced the engine. And the car bogged like crazy had no power past 5k and motor/test pipe seemed to be hot as hell but temp gauge read fine. I think its due to the dry and unefficient cylinder. Also I just replaced one of my friends injector on his BMW. Scanner showed it as misfire in cylinders 123, I checked the coilpacks and no power going to them. But nothing to do with the injector. Way i found out was with a diffrent diagnostic that reads injector volumes all were at 0.00, cylinder one at 4.63. Replaced injector and car finally ran past 80 mph.
Oh and another thing my friends BMW would also lose power from time to time. And even thou he didnt have power to the coils was because i think the ECu was progeammed to shut down the coils to prevent dry fire in the cyllinder. But it never showed a code of an injector.
Originally Posted by fireball,Oct 1 2008, 10:03 AM
u've obviously never changed one then..
Inline fuel filter=easy to replace.
S2000 fuel filter=not so easy to replace
car pulls fine when it isn't missing. goes nto vtec. she finally threw all 4 misfire codes today and the random misfire code. i'll post up the freeze frame data and the maint done to date as well as what my friend and I have found when I get home tonight.
