Bad coil packs on an AP2 non DBW FIXED
So my friend's 05 AP2 was having a weird issue that it felt like it was missing and running on 3 cylinders on occasion in particular the car would run like crap when:
-cold idling
-low rpms and cold
Once conditions warmed up or under high RPMs; the car would run great and no missing or hesitation.
The interesting part is that the car does not throw any codes.
Remedies I tried:
-changed spark plugs (condition of the plugs had good coloring no indication of lean or rich running)
-valve adjustment (usually I run them on the looser side since I do valve adjustments so often)
Finally, I had access to another friend's AP2 and was able to quickly try his coil packs...eureka - PROBLEM SOLVED!
In case anyone else has a similar condition; this would be a remedy to try.
-cold idling
-low rpms and cold
Remedies I tried:
-cold idling
-low rpms and cold
Remedies I tried:
-cold idling
-low rpms and cold
Remedies I tried:
Out of curiosity, how many miles on your buddy's coil packs? One of mine hit 99k miles and started crapping out!
Originally Posted by HarryD
Nice catch and thanks for the update! I had similar problems -- with no codes -- so yes for anyone reading, coil packs can partially go out and change symptoms as they warm/cool. Out of curiosity, how many miles on your buddy's coil packs? One of mine hit 99k miles and started crapping out!
