Backup switch (reverse light switch)
My backup lights do not light up when reverse gear is in.
Light bulbs, under dash fuses are ok.
I need to check continuity on the switch on the transmission.
The honda manual says the transmission needs to be lowered to swap it.
Is there a trick, way, method to change the switch without loosing up the whole transmission.
thank you.
thank you.
I would use a voltmeter to first measure if there is electrical current on the wires before attempting to drop the transmission to fix your reverse lights. Sounds to me, it's shorting out somewhere.
![](https://www.s2ki.com/forums/images/s2ki/ranks/moderator.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
something tells me you can just get under the car and swap it in 5 minutes...I'll check it out...
![](http://inlinethumb08.webshots.com/44807/2339706560102826257S600x600Q85.jpg)
The manual does not tell you to drop the trans.
edit: well... actually.... it kinda does.....
Not really drop as in: drop the subframe but you have to tilt & lower it.
![ashamed.gif](https://www.s2ki.com/forums/images/smilies/ashamed.gif)
It does show this fancy tool #1 though.
With the proper tools it looks like to be a 5 min job
![wink.gif](https://www.s2ki.com/forums/images/smilies/wink.gif)
![emot-tip-wink.gif](https://www.s2ki.com/forums/images/smilies/emot-tip-wink.gif)
The special tool looks like an ordinary crowfoot wrench. Open end wrench with a 3/8" square drive to fit on an extension. Available at Sears or many other tool sources. I don't know what size it is, however.
Added link to Google search results with pictures:
http://www.google.com/search?client=firefo...G=Google+Search
