Back Panel Screws OEM Hardtop Install
If memory serves me correct it is also a 7mm or 8mm hex head on the outside and phlips on the inside
If you mean that the threaded portion just spins without coming out, you'll just have to cut the plastic hanger away completely, cut the head off the bolt, pop the panel out, then try turning the shank while pushing or pulling with a pair of locking pliers.
