Axle issues?
Axle issues?
Hey guys. So I started a new job recently that has me driving further than normal. Last week I developed a shimmy while accelerating at about 60-70 mph. So I figured great it's the axles. So this weekend I got around to doing the axle cup swap left to right/right to left. Fairly straight forward just annoying more than anything. To my surprise I found almost no abnormal(or any) wear inside the cups after cleaning the fairly clean looking grease out. Driving to work today I felt it again but it came on at a slower speed. And now when I shift at a slow speed/take off it almost feels like there is "slop" there somehow. Like the diff spins and then hits the axles. Did I do something wrong? Or do I need new axles. I rotated my tires so unknown it's not like missing weights and it only seems to happen on acceleration.
Thanks in advance. Also slightly lowered on tien coil overs. coo
Have you checked your front tie rod ends?
A tiny amount of play is normal. What about your diff mount?
re check all your diff bolts that connect to the half shafts as well as the main driveline. It very well could be the tires out of balance from the get go. Sometimes just swapping them on a different axle/side of car can magnify what was an unnoticeable issue previously. The axel cup wear is much more a harsh high frequency vibration, rather then a shimmy. Tire balance is a shimmy/jiggles sensation.
You should have found inner cup wear marks from the prop shaft if that was the issue. Doesnt sound like it was to me.
