Awwww crap! Ugly sound from engine on startup.
Old 02-24-2004, 04:08 PM
DaveZ's Avatar
It's been sitting in the garage for more than a day so I went out to go start it just to see if it would make the noise again and what do you know - it didn't. <sigh>
This one is going to be difficult to troubleshoot since its not reproducable. Thinking back, I seem to recall one of the previous times where it made the sound after the engine fired and my finger was off the starter by at least a second or two.
Thanks for the thoughts so far.
Old 02-24-2004, 05:24 PM
xviper's Avatar
[QUOTE]Originally posted by gernby
Old 02-24-2004, 11:17 PM
mikecl713's Avatar
mine does the same thing too..
the sound occurs right when the revs touch 2500 at startup and goes away while the the revs fall back down to ~1000..
Old 02-24-2004, 11:22 PM
hyperpm's Avatar
Do you have a CAI? If so intake tube might be too close to throttle body and touching at start up. Just a guess since it happened with my AEM.
Old 02-25-2004, 03:22 AM
DaveZ's Avatar
No CAI. It's defintely a loud metal on metal sound.
I'm going to drive it this morning so maybe I'll hear it again
Old 02-25-2004, 05:36 AM
Big Ben's Avatar
Mine did the same thing this morning. Sounded exactly like you described it and only did it for a second. Then I tried to reproduce it and it wouldn't do it.
I'm not too worried about it. I have read of other people's S doing the same thing once in a while. I really don't think it is anything that is going to harm the engine. But I do think it is either the bendix in the starter motor or possibly the air pump motor. More than likely it's the starter motor though. Which is an easy fix. (at least an easy fix on all my past vehicles)
Old 02-25-2004, 01:32 PM
Dezoris's Avatar
What type of ambient temperatures are you starting the car in?
Is it cold?
I had several Hondas with Pulley whine when the car would start in cold conditions, after sitting.
After the car was warm any subsequent restarts would show no signs of any abnormal sounds or vibration.
Old 02-25-2004, 01:52 PM
Big Ben's Avatar
It was about 38 degrees here this morning when I started mine. But this is the first time it's ever done it. It really does sound like it's the starter though.
mikdys's Avatar
Sounds like the slip clutch on the starter to me due to the starter not disengaging quickly enough - maybe worth taking the starter out and giving the pinion area a good clean up (no idea how much work this would be!). You could try getting someone to listen with a screwdriver on the starter when you fire up to see if this is where the noise is coming from.
Just a guess though.
Old 02-25-2004, 08:08 PM
Former Sponsor
Gernby's Avatar
Only if you can find someone who doesn't need 2 ear drums...
Quick Reply: Awwww crap! Ugly sound from engine on startup.
