Awful 2nd gear transmission grind
Old 01-15-2012, 01:08 AM
  #21
AZ-S2000's Avatar
Originally Posted by trAP2
ive only read to adjust d and e never a and b... Where did you guys get that info?
Well I adjusted the thing Billman said not to, than went back and tightened the rod and not the sensor. The guy is a knowledge base of the S2000 so take his word. Oh FYI for those who did adjust the sensor, did you unclip the plug before doing that? Because you twisted the wires up, maybe nothing bad but idk. Oh also the 12mm against the firewall holding the rod on mine were loose.
Old 08-03-2015, 06:12 PM
  #22
DustinWilson's Avatar
Originally Posted by Billman250
Change the clutch fluid.
Set the clutch rod under the dash to zero freeplay. Only the master should have its built in freeplay. Remove the play in the linkage only. Loosen the 12mm nut and turn the rod with your fingers to remove the play.
Also, make sure you push the clutch all the way to the floor BEFORE you pull the shifter out of first.
Do all this, you have an 80% chance of getting rid of the 2nd gear grind.
This was amazing! Thank you. Changed to MTF and second still grinded. Spent two minutes under my dash adjusting clutch rod and boom, redlined 1st twice today and no grinds.
Old 08-03-2015, 06:45 PM
  #23
S2KCHRIS305's Avatar
Hey Billman, how do you tell the difference between freeplay from the clutch rod and freeplay from the master itself?
Old 08-03-2015, 08:51 PM
  #24
noodels's Avatar
Get your head under and look,self evident once your under there
done mine after trying hard jobs first, even considered selling it because of the crunch,
thought it was normal and needed driving skills I did not have-
5k gear changing hard work, very painfull in traffic ...
It was kinda why the f@#k did I not look there first
Old 08-04-2015, 08:03 AM
  #25
Car Analogy's Avatar
Received 1,439 Likes on 1,071 Posts
Ok, this thread is back from the dead. The freeplay thing is often misunderstood. Let me try to explain.
You will see where the clutch rod pushes on the back of the MC, on the MC piston. You want to loosen 12 mm lock nut, turn the rod by hand until it just starts to push on the piston. That is zero play. Tighten lock nut.
At zero play, there will still be enough play in MC to provide the needed play to prevent any clutch disengagement while pedal is at rest.
Old 12-28-2020, 12:17 PM
  #26
Joseph Juguilon's Avatar
This 100% worked for me. I also cleaned out my clutch fluid.
Old 01-12-2021, 02:13 PM
  #27
jahmed78's Avatar
I adjusted the clutch as recommended and my 2nd gear grind is gone as far as I can tell. Two days of spirited driving and smooth as butter. Thanks for the info!
Old 01-12-2021, 04:44 PM
  #28
Billman250's Avatar
Received 1,396 Likes on 837 Posts
Member Soviet has a great diy video of this procedure.
Old 01-15-2021, 06:43 AM
  #29
johnckeen's Avatar
mine is grumbly when cold but perfect when hot, has been since I owned it and I have tried lots of different fluids. The best fluid I have tried so far is redline MTL 75W80
Gotpepsi
03-22-2015 03:50 PM
grunyon
05-08-2014 06:02 PM
lunardeathgod
06-19-2012 03:47 AM
gravit
04-30-2007 08:08 AM
FormerH22a4
06-11-2003 04:11 PM
Quick Reply: Awful 2nd gear transmission grind
