Armchair mechanics, test your skills...
Originally Posted by S2kRally,Oct 23 2009, 02:50 PM
burning oil while idling or under a low load is typicaly oil rings. higher combustion chamber pressures get behind the rings and force them outwords creating the seal, but if the rings are worn or bad, when you dont have that outward force, oil gets by and burns off.
Disconnect the PCV system and run without it for a couple days. See what happens. Specifically, I'd pull the hose off the inlet tube and just let it suck unfiltered air.
You're really going about this backwards. The PCV is the first thing you should have serviced.
If oil is getting from the PCV system to the intake it'll smoke. If you disconnect the PCV (both lines) and it stops smoking then you found your problem. You realize I hope that you can't just disconnect the big vacuum line and let it dangle, you'll have to plug it. I'd clamp the PCV vacuum line itself and disconnect the one that goes to the inlet and let it dangle.
Originally Posted by foxy_s2k,Oct 23 2009, 07:41 AM
No problem under low load or at idle, as stated, it's when I pull away (ie under lots of load).
Sorry for my apparent lack of any kind of mechanical ability, I'm actually a really technical person, but no experience with this kind of thing.
I only see one line, like this pic. By the way, what is that thing on the far right of this pic (this is NOT my car by the way! Just an example pic showing the PCV).
