April 2005 Honda Express tech
Not sure if this one is known, but if thgere is interest, I can summarize the article.
Affects 2000-2001 S2000's.
I would scan it but as a journalist I observe copyright laws.
Here is a summary:
"In humid conditions, with the A/C on and running at max speed, water drips on the passenger's carpet. Affected vehicles are all 2000-'01 S2000's."
The probable cause is is that when the fan is maxed out, water condensed in the evaporator can blow into the heater. The heater does not have a drain valve to dispose of the water, it colects on the bottom of the heater, and can elak from the heater housing lower seam. That seam needs to be sealed.
There is then a description of the parts needed and procedure to break the old seal, and use Dow Corning 111 silicone paste to re-seal.
If you guys are having the problem, I can type up the lengthy procedure, or perhaps a friendly Honda Parts dude or dudette will share the Issue 15 Expresstech.
Here is a summary:
Is this the same issue, as in this TSB, that can be found in the S2KI library?
Here is the link for the TSB [URL=https://www.s2ki.com/stor/library/TSB/A00-083/index.htm]Water Drips on the Passenger
