app sensor replacement .
From what I've read, the accelerator pedal position sensor sometimes will take a dump in my06+ s2ks, seeing as I have had some of the beginning symptoms of this, no c.e.l. yet I have a replacement app sensor to try out and see if it fixes the sporadic and inconsistent pedal feel of my 06. Maybe a stupid question but if computer a (app) and computer b (tps) work together, I have a replacement computer a.... do I need a replacement computer b? Or is there a way to have both sync to one another such as unplugging the battery and then starting the car after install?
Thanks in advance, I couldn't find any useful information other than one discussion about the app in another country.
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
Just replace app sensor. Recommend to do battery reset procedure. Disconnect both positive and negative battery terminals . While they are disconnected, jump them together with a jumper wire. And turn key on to 2 position. Leave for 10 minutes. Then remove jumper wire and reconnect battery. After reconnecting battery. Do idle learn procedure . Let car idle till warms up till fans come on. Then let idle for 10min all accessories off . Do not touch throttle...
Can try battery reset procedure and idle learn before replacing app sensor. May help or fix problem. Since you said no check engine light.
S2K DRIFTER
07-05-2011 06:04 PM
