AP2 tranny fluid
Old 12-19-2005, 07:33 AM
Cyclon36's Avatar
Default AP2 tranny fluid
I'm at the point where I need to replace the fluid in my tranny. It seems that the best solution is the GM sychromesh friction modified fluid. However, I remember hearing somewhere that this was not good for the AP2's because of the carbonfiber sychros. Has anybody else heard about that or know of a fluid that better suits the AP2? Also, has anybody heard about tranny fluid and carbon synchros having problems with other brands?
Old 12-19-2005, 08:00 AM
Emil St-Hilaire's Avatar
Redline MT-90.!!!
Old 12-19-2005, 08:01 AM
jasonw's Avatar
Why not just use the Honda brand? You aren't getting any grinds with it now are you?
Old 12-19-2005, 08:03 AM
Cyclon36's Avatar
Not so much. I still get the 2nd gear grind every now and then. That drives me nuts. I heard the friction modified helps that a bit and the shifts feel smoother than with the stock fluid. I don't want it though if my synchros are going to dissolve in it or something though.
Old 12-19-2005, 08:04 AM
jasonw's Avatar
How many miles? Maybe you could just try flushing with the OEM fluid and see if that helps... IIRC, it's like $3.50 a bottle.
Old 12-19-2005, 08:05 AM
And,under heavy use,it does'nt last long.!!!
Old 12-19-2005, 09:10 AM
S2000GT's Avatar
I used to use the Honda MT90, but have since switched to GMSMFM as I still got the 2nd gear grind after a few hundred miles.
btw..moving to UTH
Old 12-19-2005, 09:41 AM
slipstream444's Avatar
Posted this a few weeks ago. It covers Amsoil MTF (specifically related to CF synchros), GMSMFM and others.
https://www.s2ki.com/forums/index.php?showtopic=339817
Part of my first post is a quote directly from Amsoil relating to CF synchros.
I hope this helps.
Old 12-19-2005, 10:36 AM
Cyclon36's Avatar
[QUOTE=slipstream444,Dec 19 2005, 01:41 PM] Posted this a few weeks ago.
Old 12-19-2005, 11:51 AM
acuraintegraman's Avatar
I used honda fluid for the first year then switched to the gm. I change every 7k-8k and I really didn't feel a big difference, but someone else drove my car with an 04 commented how much smoother mine felt compared to his. I've used GM for the last 14k miles
Quick Reply: AP2 tranny fluid
