Ap2 tranny in Ap1 HELP !
Old 09-29-2011, 01:43 PM
  #21
s.french's Avatar
Guys,
Does this : http://www.ricks2k.com/products/yellowbox.php and this http://www.modifry.com/products/index.htm do the same thing ?
There is a price difference between the two.. just checking !
Thanks !
Old 09-29-2011, 01:45 PM
  #22
s.french's Avatar
Oups, the second link does not work but it's the Yellow Jacket thing.
Old 09-30-2011, 01:39 PM
  #23
s.french's Avatar
Witch would you recommend ?
Price/Quality ?
Thx
Old 10-04-2012, 04:13 PM
  #24
rocketstarter's Avatar
What size is the nut on the stake nut attached to the AP2? No way in hell is that a 27mm, looks more like 35?
Old 10-11-2012, 08:01 PM
  #25
it's a 36mm nut btw. Unstake it and you can hit it with an impact, comes right off
Old 03-04-2016, 04:47 AM
  #26
ado
ado's Avatar
Billman, is it necessary to replace the nut that holds on the rear flange when installing an AP2 transmission in an AP1?
Thank you.
Old 03-04-2016, 01:50 PM
  #27
Billman250's Avatar
Received 1,398 Likes on 837 Posts
As long as the nut has been un-staked properly, the nut can be re-used.
If the nut is beat up looking on the stake surface, change it.
Be sure the white washer and black oring are installed correctly, or the trans will pass gear oil into the driveshaft cv end, thinning the grease and causing a spinning slinging leak.
Old 03-04-2016, 03:14 PM
  #28
ado
ado's Avatar
Thanks for the response Billman. I will make sure to check everything you mentioned.
mmhm
12-18-2013 09:37 AM
Anpaul
03-16-2011 01:31 PM
Quick Reply: Ap2 tranny in Ap1 HELP !
