Ap2 tranny in Ap1 HELP !
Hey guys,
I know there is alot of topics on that but I can't find the answer i'm looking for .
I just bought an AP2 tranny for my 00 Ap1 S2000.
What is the mods i have to do to make it fit ?
Can someone tell me the exact part numbers i need ?
Thanks alot !!!
Thanks alot !!!
Damn, is this flange easy to replace? If so this sounds like a MUST DO upgrade for any older AP1 with clunky/chunky or sticky trans issues. I see Ap1 MT for like $500, are the Ap2 generally more?
Billman250, i don't have to change bolts nothing ? Found that on a topic...
40441-PCY-A00 FLANGE, COMPANION $35.49 $35.49
91201-PCY-003 OIL SEAL (40X60X9) $5.64 $5.64
91005-PCY-003 BEARING, BALL (31X55X13) $13.08 $13.08
91302-PCY-003 RING, BACK-UP (28MM) $2.09 $2.09
95701-08040-08 BOLT, flange (8X40) $0.70 $0.70
90402-PL9-000 WASHER, SPRING (27MM) $3.21 $3.21
90203-PCY-000 NUT, HEX. (27MM) $3.02 $3.02
Are that parts I have to buy ?
Thanks !
Thanks !
I have a question about this too, not trying to thread Jack but do you have to pull the transmission apart or is it just one big nut on a shaft type deal? Like a 10 min job or 2 hour job?
thanks for the info the shorter gearing and the longer 6th along with less clunking sound like a nice upgrade to my car, the shift to 2nd on the MY00 leaves something to be desired
