AP2 suspension on stock AP1
Originally Posted by mikey k,Apr 15 2007, 02:46 PM
Not quite true!
I had my AP2 OEM shocks "dynoed" by Nitron before they built a set of 3 way coilovers for me.
AP2's (in Europe at least) have 250 lb springs front and rear.
The AP1's shock do have a slight rear bias but not much 240 Front and 260 rear IIRC
Front: Increased spring rate 6.7%
Rear: Decreased spring rate 10%
http://www.hondanews.com/categories/898/releases/1501
Please correct my math if needed, but assuming 250 front / 250 rear for AP2, that would imply 234 front / 277 rear.
bigteninch, if I was in your situation I would put the AP2 fronts on, and leave the AP1 rears.
Originally Posted by scareyourpassenger,Apr 18 2007, 12:34 PM
If ap2 springs are softer wouldn't this cause the travel for any movement or bump to become longer? The rear control arms on a ap2 are longer and this (I am guessing)would cause the agle/toe of the rear wheel to change less vs. a ap1 where the arms are shorter.
My guess is that a change in roll rates will overshadow the other effects, but the only way to be sure is to put the srpings on the car and do some testing.
I just put low mileage 2007 springs and shocks on my 2002 which had 55k on it. I had the car aligned at my dealer with the old suspension on it, I have not changed any alignment settings since putting on the new parts.
In my opinion the car now handles better. There is less overall body roll in hard corners. In straight line daily driving conditions the ride on the rear end seems softer over larger road undulations, but pretty similar over hard sharp bumps. It almost feels like I got softer rear springs but firmer rear shocks ?, though I haven't seen any official numbers to support that.
I love the feeling of the front in hard cornering now, I think most of my body roll was coming from the front end on my factory setup. While I expected to have more body roll in the rear end I can't say that I feel it, it might be present but I just can't detect it. I can definitely feel the difference in the front.
I don't know if my factory shocks were in poor condition or not, they looked fine. I found the ride on my factory suspension to be rough and clunky feeling over bumps, but my new suspension feels smoother, whatever that indicates. I do prefer the new suspension and ride qualities. I haven't experienced any bumpsteer situations since putting on the new parts, so it is hard to comment on that aspect. I was concerned about the effect on bumpsteer, but I haven't been in a situation where it has manifested itself yet. I've only had the setup on for a few weeks. I thought that I had more understeer with my factory setup, with the new setup it feels like the car is more neutral, the rear end feels pretty planted in hard cornering and the front end feels much sharper overall. These are all of my subjective comments whether they make sense or not based on reported suspension rates. hth.
I didn't get an alignment on mine after the swap, because I had one done only a short while ago - 2 months prior.
If you haven't had one in over a year it would be worth doing regardless. If by chance you've had one done in the last few months then you might be able to skip it. It shouldn't affect the alignment settings very much, perhaps camber very slightly if the ride height changed, but on my car the ride height appears to be very much the same.
Originally Posted by bboixtc,Sep 20 2010, 06:42 PM
Do you agree with thielepr about only swapping the fronts?
But I wanted an updated ride characteristic, the ride on my car seemed like it was pretty hard over rough surfaces. I didn't like getting jolted around. I don't know if my oem shocks were worn out or not. But I like the overall feel of the ap2 suspension, better handling on the front with a better riding (less rough) rear. Lower body roll on the front, without much of a sacrifice in the rear. Keep in mind I'm comparing 8 year old springs and shocks with 55k on them to parts that were used less than 2 years with 12k on them.
I will admit that I don't push the car to it's limits on a daily basis, but for the amount of hard driving I do it seems to be perfect. I wouldn't go back to the other setup or any combination of the two for my tastes. For some reason my ap1 never exhibited tail happy oversteer characteristics, it always seemed to understeer, I found that to be strange based on what I had read from other owners.
