AP2 retainers on both intake and exhaust? Why just intake?
In a search for comments from Billman (who I respect quite a bit)...
"It is more than ok to use ap2 retainers in 9k applications
I dont use them on the exhaust side for two reasons:
-it is extremely rare for the exhaust retainers to crack.
-it will, in theory, lower the rpm it takes for the exhaust valves to float and cause piston-valve contact
You can use them on the exhaust side, but dont mis-shift. If you do, you will bend valves before splitting retainers (kinda defeats the purpose of putting them in there)
The idea of putting ap2 retainers on the intake side is to give the engine the abilty to withstand an over-rev.
IF you are 100% confident you will never mis-shift, then surely it is ok to use ap2 retainers on intake and exhaust."
But...we have seen S2ks with cracked exhaust retainers. I have fun with my car but don't drive it crazy. Will I ever miss-shit? Who knows...I did it twice with my AP2. Each time I caught it before I let the clutch all the way out. I've been more careful with my AP1.
Maybe I don't know what's best but I hope I made the right choice. Either way a replacement head is cheaper than a new engine. I mainly chose to replace all 16 because the foreign F20C motors use the new retainers for all valves, intake and exhaust.
DONT!! replace the exhaust side with AP2 retainers because the AP1's are designed for a higher lift. If you replace the exhaust side with AP2 retainer, you are defeating the whole purpose. Replace the intake side with AP2 and exhaust side with brand new AP1's. By replacing the exhaust side with AP2 retainers you are bringing down the duration and lift limit of the AP1. So therefore even if you go to 9k you will crack them and drop a valve. But don't quote me on this, ask billman
