Ap2 oil banjo bolt
I kinda hope everyone puts away their spoons and stops spoon feeding you. All the info is here. Check your / build date VIN. Do a little homework.
Here's your homework. https://www.s2ki.com/forums/s2000-un...2A-%2A-548714/
It's about a 90% must do upgrade.
You do do realize that some applications remove them all together right? Some stroker builds live long and happy lives without them.
I have seen seen far more threads of screwed up attempts vs screwed up motors from the old bolts
The 90% was a play on the OPs post.
You can pull the oil pan and find out. Remove one of the banjo bolts, if it has 2 holes, you're good.
seriously? You sure are on a roll for the most thoughtless posts of the year award. Have you tried doing any basic research concerning any of the questions you might have?
