AP2 gauge cluster in AP1 with F22C
Old 06-23-2009, 03:54 PM
TheCarGuy2021's Avatar
[QUOTE=negcamber,Jun 23 2009, 06:30 PM] If you use the AP2 ecu instead of the AP1 ecu with your F22 motor, you are leaving one of the best performance mods unused on the table.
An s2k with an F22 motor revving to 8500rpm is significantly faster 0-60 and 1/4 mile than either a stock AP2 or AP1.
Old 06-23-2009, 03:56 PM
Originally Posted by Stratocaster,Jun 23 2009, 06:13 PM
On that grey connector, you could remove the grey connector from wires and leave the connections connected. They will slip into the other grey connector.
Thanks for the tip. I just need to find out what system uses the grey connector that doesn't matchup with the 2 white ones.
Old 06-23-2009, 04:17 PM
Looks like for every wire color on the grey (AP1) connector, there is a corresponding matching wire on the white (AP2) connector. Is it possible that the extra wires in the AP2 harness are just for additional features of the AP2 cluster? I think I'm going to try and connect what I can and see how it comes out.
Old 06-26-2009, 01:05 PM
Anyone know if I can just put the connectors to the gauge cluster on the AP2 harness on the AP1 harness?
I haven't checked to see if the number of wires and colors correlate, but it's an idea. Seems to be the easiest work around.
AV Engineering
01-21-2011 09:12 AM
f20cmx5
Member S2000 Classifieds and For Sale
08-12-2009 03:05 PM
p3tah
05-16-2008 09:22 AM
Vinsfeld
12-19-2007 03:47 PM
phillys2k
09-21-2005 10:58 AM
Quick Reply: AP2 gauge cluster in AP1 with F22C
