Ap2 front end swap with ap1
Wanting to know will everything be bolt on? Mainly suspension/stearing/rad, rad brackets. The ap1 is 2002 the ap2 is 2006.
I know the fenders bumper and headlights is not a problem.
Thanks
Thanks
Received 1,377 Likes
You don't want the steering rack from the AP2, although I'm almost positive it bolts up. It's a slower ratio. The shocks/springs will bolt in. The front control arms should bolt in. The radiator should also bolt in.
The cosmetic body peices all bolt in although you need the AP2 fender liners to properly match the AP2 bumper...or you can buy special clips for the AP1 fender liners.
The center splash guard is the same between the 2 cars. Same part number.
