Is this the AP2 ECU layout?
Question:
What's the diff between Karman Vortex type airflow meter and Hot-wire airflow meter/Flap type AFM or Pressure sensor?
I'm using the Fujita F5 CAI, utilizing stock flow sensor..
Google is your friend:
http://www.google.com/search?hl=en&q=Karma...+meter&aq=f&oq=
The pics in your other thread are not showing up. You'll need to post them on a site like Flikr and then post the links in your thread.
The host site is up again. try seeing again.. thanks.
So the S2k sensor is consider wat type? Definitely not Karman type.. It looks like a NATO 5.56mm blank round tip.
And just an update, i have remove my ECU and confirm the shape of it.. pardon my manual method.. And I learn it is the same ECU std connector used in the K20A type as well. So the layout is found in the installation manual (E-Manage Ultimate) same as EP3 CTR & DC5 RSX (K-pro mentioned using this map too and slight mod to be use on AP1).
As far as the ecu pinout for a DBW car, the only recommendation I can give is to purchase a Boomslang plug-n-play harness. I know that the pinouts for MY00-05 are all the same. But they are different for the MY06+ cars.
http://www.boomslang.us/ultimate.htm
