AP2 ECU in an AP1?
can you still get your key cut and not programmed?
if so, im sure you could use a bypass transponder sold in alarm installation shops.
they are about 30 bucks and are used for remote starters.
I might be wrong.
I might be wrong.
Thanks a ton for the info guys. I imagine my friend will have the lock cylinder as well, he bought a front clip with the engine in it, so I don't see the point in having the keys without the cylinder if it's not all still in the original car. It's an '05 ECU so the drive-by-wire won't be an issue.
I think as long as he has the cylinder I should be fine to get it running while I track down the key code so that I can get keys cut for my original ECU. I never figured it would be such a hassle to get keys cut for this car though...
Hold on! Let's back track a little bit here. If you are putting in a different ECU, you are still using your existing immobilizer unit. You should be able to use your current key. The key code is stored in the immobilizer. As long as it tells the ECU that all is well, the ECU should still allow the fuel pump circuit to be completed.
Are you sure about this? I thought the code was in the immobilizer circuit board that's built into the ECU (which is a Delco part on other Honda ECU's). I was under the impression all the thing on the steering wheel was is an exciter/receiver.
You should be able to do the key tape trick they describe in the manual though. Tape the two keys together so both are read.
After looking at the manual, I see you are correct. However, since each ECU can be coded with up to 6 different key codes, it would be matter of getting a dealer to program the current key code into the new ECU.
Originally Posted by Stratocaster,Aug 9 2006, 01:45 PM
Dude
This is where your 59 days on the board is starting to show.
After reading though some of Ek9's posts, he seems to have quite a bit of knowledge and has posted some interesting and informative posts
He is no xviper though
I've gotten to relying upon memory of late or not answering at all. And my memory ain't so good now and then.
