AP2 diff and gearbox in to AP1
Hi,
I'm rebuilding an AP1 with intentions to supercharge.
Collecting an 2005 AP2 gearbox and diff tomorrow, as I'm aware the diff would need a part swapped from the AP1 diff, to match to the ap1 prop.
Questions:
-Should I just get the prop with that aswell and swap as a whole?
-What is the easiest way to check if they are the AP2 bits? (any numbers stamped on them? any obvious visual differences?)
-uk spec ap2 gearbox has the carbon syncros doesnt it?
-ap1 driveshafts will work fine? -(read up a bit on spacers,since the whole rear subframe is coming out for a refresh I will go for 1 piece 10mm spacers for the peace of mind )
Any other advice etc is more than welcome
Thank you!!!
Questions:
Thank you!!!
tylorweaver
02-21-2008 04:52 PM
