AP2 axles longer?
Old 05-08-2008, 04:48 PM
  #51
negcamber's Avatar
Axles are the same part number for AP1 & AP2...no difference.
Old 05-08-2008, 10:18 PM
  #52
1320performancefreak's Avatar
okay i guess the axles i have for ap2 will work on my ap1 then. what work do i need to swap the ap2 complete diff on to my ap1?
Old 05-09-2008, 09:22 AM
  #53
jyeung528's Avatar
how is the drive shaft different?
Old 05-09-2008, 09:50 AM
  #54
fltsfshr's Avatar
Received 1,058 Likes on 540 Posts
It has the other flanges on it and is a little different diameter. I don't it weighs the same either.
At least that's what I thought I noticed when I switched out.
Old 05-09-2008, 02:03 PM
  #55
jyeung528's Avatar
thanks.
what are the alleged improvements over ap1...
i want to do a quick benefits to cost analysis and determine whether I want to do this upgrade...
Old 05-09-2008, 02:07 PM
  #56
fltsfshr's Avatar
In an ap2 tranny the secondary reduction gear is 1.6 compared to 1.25 in an ap1.
both 5th and 6th gear are a little higher 1 thru 4 ratios remain the same.
Ive been told it will feel like you installed a set of 444's in an ap1
fltsfshr
Old 05-09-2008, 02:26 PM
  #57
jyeung528's Avatar
i should've been more clear...
i understand the ap2 transmission ratios, what i meant was the alleged improvements of upgrading to the ap2 driveshaft....
Old 05-09-2008, 02:31 PM
  #58
fltsfshr's Avatar
I'm assuming that some of it has to do with protecting the differential a bit more. I don't know for sure. Other than a tempering change in the differential housing, they are identical.
I don't think the change is enough to make a rotational weight difference of any consequence.
I'm not sure about honda prop shafts but many drive shafts are balanced to the differential and marked accordingly (sometimes with yellow chaulk)
fltsfshr
Old 06-22-2010, 09:03 AM
  #59
inactiveuser1114's Avatar
so do AP2 need spacers yes or no?
Alexss2k
04-16-2012 06:27 AM
HavefuNs2k
Αμάξωμα - Κουκούλα - Εσωτερικό
01-29-2010 10:00 AM
S2KHardTop
07-20-2006 03:36 PM
Quick Reply: AP2 axles longer?
