AP1 wont shift into 6th
Old 06-08-2012, 12:26 PM
WayneCallar's Avatar
Wow I 'skip shift' all the time! Always have! Never would have thought in a million years it would be a bad thing lol! In fact I hardly ever use 5th gear lol! Whoops!
Old 07-22-2013, 05:23 AM
Ahdil's Avatar
Im going to try this because i have the same problem with my 6th gear not selecting at all, hope it works for me!!
Old 09-08-2013, 09:44 AM
Ahdil's Avatar
Hahaaa its fixed! However mine was resolved after simply driving the car in fifth taking it 7k for around 20 miles. On my return journey i just tried to pop it into 6th, slightly stiff but went in! , then i just repeated it many times and now its fine.
I did try the method stationery method but didnt work for me so i gave up. So if you have the same problem give this a try.
Old 10-15-2013, 04:45 AM
66elwood99's Avatar
I had tried all the mentioned solutions. (Side Note, 7K in 5th gear had me doing around 110 mph). I did not change fluid which will be my next step. Any other suggestions before it gets operated on?
Thanks
Old 04-01-2014, 10:42 AM
ienkkk's Avatar
Originally Posted by Billman250
now go find some open road....in 5th gear, hit the gas wide open to 7k or so, coast to 6k, hit it to 7k, coast to 6k, and so on. Hit the the throttle hard and pin it.
this will flatten the burrs.
Old 04-01-2014, 10:43 AM
ienkkk's Avatar
I just wanted to thank whom ever posted this, I too suffered from the same events, fixed it with your information. Thank you!
Old 04-01-2014, 03:51 PM
Utah S2K's Avatar
B-Man is one the, if not the, most knowledgeable mechanics here on the board. He is off to the Dragon (large S meet) so may not see this for a day or two. But I'm sure eventually he'll find this post. Welcome to the S2Ki Community!
Utah
Old 04-01-2014, 04:18 PM
drew260187's Avatar
Oh crap ive been skip shifting and only posted other day sayin im having issues with 6th gear grinding from 4th directly into 6th? I hardly use 5th also, leason learnt will try only going from 5th now and see if im still grinding when i change.
Old 04-02-2014, 08:14 AM
Needsmorepower!'s Avatar
Maybe it's just me but I find it extremely satisfying rowing through the gears and hearing my f 22 change pitch and continue pushing me through the digits. I skipped one gear and I missed the satisfaction. Glad this is a relatively easy fix.
Old 04-02-2014, 08:43 AM
SheDrivesIt's Avatar
It's not like "this is an easy fix so it's OK to do it" situation. Skipping gears is BAD. It creates burrs on the gear and this is what you are removing (the burrs)with the "fix".
Best practice is to not skip gears. You don't have to engage them, but you should row through them.
Say Chi Sin Lo
02-20-2019 07:38 AM
cloud70
05-13-2017 06:56 AM
Red97GST
04-23-2012 11:36 AM
rob!
Member S2000 Classifieds and For Sale
06-17-2008 05:44 PM
suzukali
06-27-2006 11:52 AM
Quick Reply: AP1 wont shift into 6th
