Ap1 vs. Ap2 injectors.....
Originally Posted by JDMilanoEG,Jul 30 2007, 02:41 PM
Because I had that check engine light problem where its giving codes for misfire, random misfire, and so on. And after numerous fuel injector cleaners and such, I cleared the light and wound up melting a piston when the injector failed.
A failed injector will usually just cause the motor to buck hard and not run properly. You will definitely be able to tell and usually get a lean cut before any serious load is applied on the motor, but it shouldn't cause a piston to melt.
I was driving pretty spirited down a mojor highway late at night, With no other traffic around. And as I hit 6th gear and accelerated, the car stayed steady. It didnt go any faster it just stayed at a consistant speed. I let off, Drove it home without any rough idle or noise. Parked it and heard it start piston slapping. Pulled the head a few days later and had a scored cylinder wall in cylinder 1.
The piston expanded, So if thats not considered melting, I guess it just deformed. It expanded enough to score both sides of the cylinder wall. Heres a few pics of what I found when I pulled the head.
Notice the problem? lol.
Good....
Not so good....
Good...
Not so good....
And finally....my solution to the problem (Besides switching to the updated banjo bolts)
Good....
Not so good....
Good...
Not so good....
isthisusernameavailable
02-15-2018 06:42 PM
gst19psi
04-08-2014 10:23 PM
