ap1 S2k no start, no crank
Old 05-31-2015, 10:17 AM
wherezmytofu's Avatar
Default ap1 S2k no start, no crank
Hey guys, my car suddenly stopped starting. no crank, no reaction at all when pressing the start button
story: driving fine, took it to smog guy. he unlocked the car using the key. then started the car to the smog station, smogged it, then let me drive off. i was driving off and the car just stalled, all lights normal stall, when i was leaving the parking lot. tried to restart, dead.
no clicking, no cranking, no light dimming.
gas was kinda low only 2 ticks left, so i had my brother come with a gas can. no go
push start it and took it to my uncle shop. he tested starter, starter wires. all fired right up.
new battery, still no go
so far what ive tested/checked:
starter
battery
all fuses
start button (my neighbor has an s2k, i tried with his)
shorted clutch lock
green key goes away when i put my key in
any ideas?
Old 06-01-2015, 06:52 PM
<Luvof2kTX>'s Avatar
Just a shot in the dark.. Clutch safety switch? If it breaks it won't relay the message that you're pressing the clutch to start the car...
Old 06-02-2015, 10:51 AM
Slowcrash_101's Avatar
He can push start it, and jump start it, I'm guessing try a known working ECU.
Old 06-02-2015, 11:51 AM
already bypassed the clutch
...damn...where to get an extra ecu LOL?
Old 06-02-2015, 12:05 PM
ask your local forum if anyone would be willing to swap. Lots of people get stand alones and have spare ecu they'd be willing to sell ya, usually for less than $100 of course you'll have to re-program your key, but sometimes you gotta deal.
Old 06-02-2015, 01:16 PM
GripSession's Avatar
Check fuses 3 & 21 & 46 in the underhood fuse box
Also check ground G401. It's a 10mm bolt with a bunch of ground wires hooked to it under the left side of the dash near the fuse box.
Old 06-02-2015, 02:12 PM
Thx man those where the fuses I checked. #46 is listed as alternator tho?
Old 06-02-2015, 04:51 PM
Fuse 46 also powers the DLC, ECM and some ignition related components. The DLC (data link connector) was probably plugged into at smog I assume. Perhaps you/they have a bent pin in that connector which could pop various fuses.
Old 06-02-2015, 04:53 PM
Also find someone with a scan tool and hook it up to check for DTCs. If it's a nice scan tool you should be able to watch the ECM commanding various systems/parts of your car on and off like the starter signal.
Old 06-02-2015, 08:51 PM
superchargedk20's Avatar
I'm interested to see how this one plays out. Good luck man!!
Quick Reply: ap1 S2k no start, no crank
