AP1 running rough, HELP
#32
I've got the EXACT same problem as you. Getting my valves adjusted today. I'll report back.
BTW, nobody ever answered you on removing the hoses the easy way. A little WD40 helps, but he trick is use a pair of pliers to twist, or rotate, the hose on the fitting. Then they'll pull off fairly easily. Tell me how it works for ya.
#37
Hey lap1, good news finally. at least someone's S2 is back to running tip-top, haha.
I read in another post as I was searching "no power, power loss". And billman suggests removing the 02 pre cat, tieing it off to prevent damage, then going for a drive. If the car runs better then that's evidence of a clogged car/exhaust system and if it makes no difference, you've ruled out one of the more likely causes. Just figured I'd mention that since it's a little easier than a valve job.
#39
Have you done anything with the coils? Swap/etc? My car wasn't throwing any codes and it stumbled while idling and accelerating. I had about 100K miles at the time(last year). Replaced the coils and all is well since.
Definitely check the coils before doing more expensive replacing/repairs.
#40
Skip the cat, valve adjustment is easy. Not to mention two or three people have told ya that a valve adjustment fixed the exact same problem you are having. This is a requirement at your mileage anyway. It needs to be done, no matter if it fixes your problem or not. There are guides on here to do it.
