AP1 running rough, HELP
I have an '01 AP1 with approx 110k miles, daily driven. Car has always had what I consider to be a pretty severe oil consumption problem, but I've always kept up with the oil levels. Last 5k miles or so, car has been gradually running worse and worse. When I first noticed the change, I decided to change my oil and spark plugs, thinking that the 105k on the OEM plugs may have been the culprit. Car ran a little better for a day or two but the problem definitely wasnt fixed.
Car seems to have a pretty drastic loss of power; shifter ring is horrible some days, will literally shake and rattle the WHOLE time im driving, when I push in the 'play' in my clutch I can feel all sorts of shaking in the pedal that go right along with the shaking that the shifter is doing; when idling, it will sometimes drop to 600 rpm, shudder horribly and almost die, but will go back up to about 1000rpm and idle there. Also, the motor and tranny arent near as smooth as when I first got them, shifts are probably about 80% as smooth as they were at first, and the motor seems to always 'strain' and sounds like its doing so.
I've done the MAP whack, didnt help at all. Maybe I should start with changing all my fluids and go from there?
I'm stumped. Could really use some help! Thanks!
No CELS. Would I be better off buying all the equip to do a compression/leakdown test or should I just have a mechanic do it being that this is usually only a one-time thing? Have never cleaned throttle body or IAC or PCV.. Should I start with these three or get the compression/leakdown test done first?
Never hurts to have your own tools . Never know when you might need them again. I would start off by cleaning the throttle body and IAC. That may very well be the culprit of the poor idle, and both are very simple to do. Also replace the PCV valve
i was going to say the same thing. Preventative maintenance goes along way, Change pcv and air filter if needed. Clean TB and iacv. Whens the last time you changed the transmission and differential oil?
Air filter, spark plugs, and oil have all been changed within last 2500 miles. Tranny and diff fluid were changed at around 40k by the previous owner, supposedly. But im starting to question that with the way the car is running. I'll take it this week to get them changed and will change PCV, clean tb and iacv this weekend.
