AP1 Retainer Replacement...Valves? Springs?
2002 So I am right on the cusp of the transition to the new jet bolts. I've seen some discrepancy on the transition numbers/dates. Additionally I have read that the bolts will fail regardless, and have read multiple posts of engine failures having the symptom of failed oil jet bolt 'valve' failure. I figured they're worth checking even if my engine number post dates the transition to the new ones.
I'm with you on that preventative maintenance crew. Since you're already taking care of the banjo bolts and retainers, what about a Billman TCT to top off the AP1 preventative care trifecta?
bad_driver (03-20-2024)
Received 1,418 Likes
The banjo bolts are a risky procedure, so just make sure you actually need to replace them. And needless to say, be very careful if you do decide to replace them.
The banjo bolt related engine failures that I have heard of were from extended 6K+ RPM use on derestricted roads. Like...constant high speed use on the German Autobahn or something.
CouchHobo (03-20-2024)
Cross threading is common on the banjo bolts. Even seasoned wrenches can have difficulty with this job.
Do ap2 retainers and ap2 cotters.
I recommend you DO NOT do the oil jet bolts, unless you plan on future forced induction.
The following 2 users liked this post by Billman250:
CouchHobo (03-21-2024),
windhund116 (03-21-2024)
d0nkeyxPunch
Member S2000 Classifieds and For Sale
12-19-2006 07:50 PM
