AP1 Problem/s
#21
^I agree, but I think part of his original coil is still lodged in the spark plug tube. I think that would probably require some pretty trained/experienced hands and a scribe/hook to remove.
240sx KA engines with shitty plug wires would frequently leave a rubber boot over the spark plug which is buried down in the head just like The F2x. I have spent a couple hours fishing those suckers out and it isn't fun.
#22
thing is Im not paying for anything ![biggrin.gif](https://www.s2ki.com/forums/images/smilies/biggrin.gif)
Warranty is paying all that..
so AP2 coils will fit without problems on my AP1? and AP2 coils are the same as CRV Coils? I still have time to keep the CRV ones.. and my coil didnt failed.. my spark plug tread did.. therefor everything in that hole got messed up
#23
Yes, CRV coils are the exact same thing as 2004-2005 AP2 coils. 2006+ AP2 coils are different because of Drive-By-Wire. 2004-2005 AP2 coils fit on the AP1 exactly the same as stock AP1 coils. Same plug, same size coil, same bolt hole, etc. Externally, they are identical as far as I could tell. Personally, I would opt for the CRV coils because I had a stock coil fail on my AP1. Just because one coil failed doesn't mean they are all doomed, but all the searching I did indicated that the AP2 coils never fail. I replaced all the coils with the AP2 coils and I have my stock AP1 coils as backups.
I would make sure they are OEM Honda CRV coils and not some off brand.
The best way to find interchangeable parts is by comparing part numbers from the manufacturer.
#26
Yea, I think they are, as well as the accord. If you google the part number, it comes up with tons of applications. It is basically the generic Honda coil. From a business perspective, it is much cheaper to just build one type of coil that will work in all applications.
Puppy
09-08-2008 12:50 PM
