AP1 Oil squirters
AP1 Oil squirters
So I have a spare AP1 (2001) engine that im building for boost. I was going to go ahead and order the updated squirters for it but then came across this article of a guy building a 2.4 who stated:
"Although the factory oil squirters can be used if modifications to the nozzle are made, Castillo recommends using AN plugs to seal the factory squirters. "The less shit dangling around the piston area, the better. Besides ... you can make up for more oil pressure and horsepower without those things."
http://www.turbomagazine.com/tech/0609turp...uild/index.html
Any thoughts on this? Do they REALLY need to be updated then if this guy is completley removing them on a modified engine?
They get close to in the way when you stroke to 2.4.
If you have sleeved your engine your old squirters are fine. If you are running the factory cylinder walls then go ahead and update.
I managed to retain the oil squirters in my F24C. I had to notch the pistons very slightly and bend the squirter jets to clear the piston.
see
https://www.s2ki.com/forums/index.php?showtopic=692401
for pictures
see
for pictures
Scigheras
06-29-2020 09:19 AM
