View Poll Results: For you qualified AP1s, Did you replace your Oil Banjo Bolts?
Voters: 172. You may not vote on this poll
AP1 Oil Banjo Bolts aka Oil Sprayers
#21
142k and change, turbocharged the last 8-10k miles boosting 10.5psi at 359rwhp. I also dont drive like an a$$ and the fastest I have taken it was been 120. Also have been to 1 autox and 2 1/8th mile strips while on boost. No issues.
#23
![](https://www.s2ki.com/forums/images/s2ki/ranks/moderator.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
On the engine block by the cylinder head, by the front left corner of the valve cover.
It is also on a large white sticker on the timing cover. 50/50 shot of reading it there. If your car is clean you should be able to read it off the timing cover.
#25
thanks Billman, were you ever able to compare the new style oil pump to the old style oil pump? I remember you asking what kind of conditions you should subject them to but I never remembered what kind of result you got. Also I noticed that you said that motors that were either supercharged or turbocharged you saw scoring on the #4 cylinder, do you think that would also be the case on early model normally aspirated ap1s that see the track regularly? It seems that it is a must if you are forced fed but not entirely if you are normally aspirated?
#26
Thanks for the info billman. Question: What sort of symptoms do you see WITh a scored 4th cyl? Increased oil consumption? Oily spark plugs? Smoky exhaust? Or is it a silent killer..?
#27
damn you HoA for not recalling this! My engine block sticker has worn off. And I cant get a decent look at the serial number due to the birds nest of wires. The vin# digits on my dashboard are 8386 and the the sticker in the driver side door jamb says it was "ltd: 07/2002" which im assuming is made in July 2002. I feel like ill lose sleep over this.
#28
Have not seen a scored cyl on any NA car, even those that are tracked. The DECEL on the track has a cooling affect. It's sustained WOT operation that causes the failures. Somehow Forced Induction has the same affect, but you only need to do a WOT run for a short time.
Number 4 cyl failure signs are a metallic rapping sound. Quiet on startup, progressively louder as the car warms up.
Shut the car off while hot and check the compression, the #4 cylinder will have HIGH compression, due to oil flooding of the piston.
Get a long skinny penlight in there. you'll see your numbers.
#30
isn't the production number part of the VIN number ? , on vehicle that has not had an engine swap ?
