ap1 with a new motor?
ok here goes...
i have an ap1 and going to swap ap2 motor in, dilema is that the throttle body on the new motor is the electronic one. now i dont have the wiring harness for the new motor and was planning on using my old ap1 harness and transfering my old cable throttle body to the new manifold. since i will be using the old setup the wasy i just described, i also have the new style ecu..... having a driveby wire ecu to work on the *ap1* style motor is that even possible??? i guess what im trying to say is...
AP2 Motor with ap1 throttle body will it work with the 05+ecu? will that work?
or should it be like this= AP2 motor-ap1 throttle body-ap1 harness-ap1 ecu= no problems ????
WHAT A PITA!
WHAT A PITA!
I have never done it, but i would assume that the ap2 ecu will be looking for some kind of signal with the throttle body which of course the ap1 tbody will not be giving. so a check engine light would be set. it seems like you have two options...
ap2 motor, ap2 harness, ap2 tbody, ap2 computer, ap1 car
ap2 motor, ap1 electronics including: ecu, harness, tbody etc. etc.
im sure there is better people to answer this then me, I am good with cars but very new to the s2k life.
MYXX Comparisons
MY06 Review
04-05 Same ECU
06+ =DBW
I know people take a AP1 ECU with the 9k rev limiter and put it on an AP2 (MY04-05) and to the best of my knowledge it's plug and play.
So the question is:
Do you have your MY mixed up........?
Did you type the wrong MY
Best question is - What is the MY of the Motor and ECU? and....are you sure?
It may work if it's 05 and down.
MY06 Review
06+ =DBW
So the question is:
snowflake
29
06-27-2012 03:30 PM
OneSilverS2k
02-12-2011 12:37 PM
